Jakes66snake
Active member
xctasy":2gbqtrbk said:Oh yeah, Option 4, from a while back. I suddenly remembered this one, which is almost the same as the Rover 4600 piston balldrick uses in his supercharged XKNO1 1961 Falcon. Since the Buick V6 and Rover engines from the same GM family. Its the N code 89-93 GM 3300 piston, the little brother to the GM 3800 found in all the front drive Buicks and Oldsmobiles
See viewtopic.php?f=3&t=67792, Crossflow tips!!
bookworm007":2gbqtrbk said:Yeah I am guessing its a mistake on their part too, but new plan that wouldnt involve expensive sleeving. These pistons http://www.summitracing.com/parts/UEM-1743H-5MM/ have a compression height of 1.310 in and a bore of 3.720 only requiring a .040 overbore which is very conservative. If you used these pistons with 300 rods which have the same big end dia as the small six engines the piston would only poke out -.0057 inches before machining. Which is pretty darn close to zero decked. the piston pin hole would have to be opened up by .007 inches so very minor, and with a 62cc head 9.5:1 compression ratios are a possibility because these pistons have a 12.67 cc dish!
This piston allows the stock shallow deck GM 3800 piston with 12.67 cc fit a 6.21" Ford 300 rod if its wrist pin is bronze bushed to suit
This looks like an affordable way of correcting piston height but are there any negitive effects of using a longer rod on an already long rod engine? Does it change the peak hp at a given rpm level? Oh I assume we are still talking about a US 250 right?
Also this combo doesn't help if you are looking to run a CI 50cc head tho if the stated numbers are correct at 9.5-1 at 62cc....right?
