rickwrench
No driveshaft shortening required? Hmm.
Aluminum driveshaft is quite a bit larger in diameter that the stock shaft. I had a few issues using an aluminum police/crown-vic shaft. The much larger diameter aluminum shaft cuts into the upward range/travel of the rear suspension. New leafs and a big rubber dif bumper fixed it.
"Crossover" U-joints are available for most sizes. I used a 1330x1310 with the aluminum shaft. If you need to adapt an 1100 series u-joint you'll be better off getting the driveshaft modified.
That said, I originally had some adapter cups made that created a 1100 x 1310 joint (Mav 8").
Watch your driveline angles, too.
Pic: S10 shifter location on my Squire. I'm tall, and the (custom) seats have extra travel and are all the way back in this shot.
Console is relocated back a couple inches, too.
