All Small Six Continuing the journey - T5 Upgrade
Hi Don and Andrew.
Thanks for the follow up!
I resolved the video issue, very nice work and congrats. I never posted previously so that was probably it. Guess I'm in with the cool kids now.
Andrew do you know the gearset on yours?
Anyway I posted my thread in the link below, it's long so apologies! If you have time I would really appreciate your input.
Thread 'T5 on small pattern 200ci swap' https://fordsix.com/threads/t5-on-small-pattern-200ci-swap.87946/
Well, now that the 200 is running well in my 66 Mustang, it's time to sort out the rest of the drive line. The weather up here is pretty crappy still, so I'm not sure when I'll have the car up on stands so I can wrassle the 3-speed out (again) and install the T5 but I now have all of the parts I need!
T5 from a Fox Body Mustang (4 cylinder model) - Check
T5 Shifter - Check
T5 for 1966 Mustang Adapter - Check
T5 for 1966 Mustang Transmission Crossmember - Check
C4/T5 Transmission Mount - Check
9" Clutch and Diaphragm Pressure Plate Kit (1978 Ford Fairlane 3.3 L) - Check
Throw out bearing for 1966 Mustang - Check
Pilot Bearing for 1983 Ford Ranger Deisel - Check
Slip Yoke - Check
I bought the T5 kit for Ford 200 from California Pony Cars. It is specific to the 1966 Mustang but they also have a 1965/66 Mustang kit for Ford 200 which is a bit less money but I know that they bell housing, flywheel and clutch is different for a 65 so I grabbed the 1966 specific kit. I will have to pull the existing transmission out to make sure it is the correct adapter but everything else I have in the kit is a good fit.
The transmission tag is 13 52 207
It appears to be a 1992 World Class with the following gears:
Rev - 3.70
1st - 3.97
2nd - 2.34
3rd - 1.48
4th - 1.00
5th - 0.79
I looked at it compared to a 1992 V8 and the V8 gearing is much much taller except for 4th. All 4th gear T5's have 1.00 but the 1983 SVO 5.0 Mustang transmission is almost the same ratio as this one.
I have a question about the transmission mount. The original mount had a plate with a rubber piece hanging off the side, on the passenger side. It mounted between the transmission tail shaft housing and the transmission mount. Is it a damper for vibration or did it serve some other purpose. I think I may clean it up, hit it with some rustoleum from a can and then reinstall it.
I'll add more when it warms up and I can get under the car to do the re and re.
I am following your project closely as I want to convert C4 to T5 in a 1965 Coupe with I6. 😁
BigE, the 65 is a different animal from 66 for the T5 swap. I'm not finished with my swap, but here's my thread so you can learn a bit.
Step 1: confirm your engine bolt pattern. You can do this by the casting number on the passenger side and looking online to decode. Unless the engine has been swapped, you likely have the small pattern 200 which is more complex than the 66 with their dual pattern block. Good luck, be sure to use the forum, they give good guidance.
