Inline6Merc
Hi all! I've been trying to dial in mt setup for the past year. I have yet to uncover the setups true potential. I'm currently running a 200ci motor, with 10 to 1 compression, clay smith 278 (110 lobe)cam, CI head, DUI, and a Pony Carb's 480cfm carb. The rest of the drive train is a C4 tranny with custom high stall converter and 8inch rear.
Problem 1.
That the car idles at 1200 in drive. The carb idle set screw is all the way out, and the vacuum is hooked up to the manifold. Timing is set with a vacuum gauge. I get 19" in park and 14" in drive.
Problem 2.
The car seems to have a miss as the tach fluctuates between 1200-1100 or so. Along with that when idling in traffic the car starts to load up.
Problem 3.
From a dead stop if I accelerate hard (WOT) the car takes off and winds up to about 3000 rpms and falls flat to about 2600 rpms and slowly crawls up the rpm range until I take my foot a bit out of it. The thing is from a dead stop the car doesn't even light the tires up. The tires are pretty old with not a lot of traction and the rear gears are 3.50.
The Dizzy advances 24 degrees @ 3000prms according to the shipping papers that came with it. The carb came already adjusted from Pony with 43 jets in the primaries and 62's in the secondaries. Fuel pressure is around 6psi.
I've been thinking about the problems and am curious if the vacuum canister can be adjusted to lower the idle rpm. Also if timing from the dizzy or cam advancement is playing a roll in the lack of low end performance or if its carb related. If any other questions regarding the set up is needed feel free to ask. I'm looking for any help at all and thanks in advance!
-Curtis
Problem 1.
Problem 2.
Problem 3.
-Curtis
