HowdyAgain MRaley:
Last time I posted I said "Last question" I guess I lied, but I've been thinking on the before and after comparison and have more questions. I hope you don't mind.
Did the compression ratio change between the Log and the Oz head swaps?
Is the 264 cam degreed start up?
As several have already stated the increase in HP and torque is so surprizing that I have to look for a better explanation then just ambient temperature (although, I'm sure that is part of the answer). If the head alone had accounted for the figures, I'd accept it, but the addition of the Holley 350 could, if properly tuned and direct mounted on your engine, account for most of that increase alone.
Adams observation about port size cause me to think that the real HP may be above the capabilities of this cam(?). If the cam is currently straight up, you might want to consider advancing it 4 degrees to get it to come in higher in the rpm range, to take advantage of the breathing ability.
I'm also mystified at the increases attributed to the DUI ignition. The only thing I can figure is that your DS II curve was less then exact and the DUI hit the mark. Tuning is all the difference.
Once again, results point out that an engine is a package. All parts must be planned for a specific goal.
Again, thanks for sharing.
