I'd leave it in, and just about 1/16" larger in diameter around the holes.
addo":7kffobif said:I'd leave it in, and just about 1/16" larger in diameter around the holes.
asa67_stang":1fsvg2ec said:X, are you sayin you see nothin wrong with my plan? what about that bit about the center section?
xecute®™© he he":2pp78tin said:asa67_stang":2pp78tin said:X, are you sayin you see nothin wrong with my plan? what about that bit about the center section?
Yes, Evan, there is nothing wrong with your plan. As I said long ago, anything you do will be an improvement.
A bad plan, well excuted, is going to improve the air flow and power of the log head. It doesn't matter if its got issues, its going to improve performance, and can't be worse than the original.
addo":3hklaivk said:I'd leave it in, and just about 1/16" larger in diameter around the holes.
