To recap, I did not like the way it was clocked with the vacuum nipple pointed at the dipstick. I changed that.
If it dies, how will the light still flash. If you mean to watch the light when it dies, I could try that. Good idea.
It's not fuel. It ran perfect with the stock dizzy.
With the stock dizzy, I could set the timing to just retarded of where it kicked back and it idled and ran fine. I could idle down to where I could damn near count the rpm.
I appreciate all the help guys. This is just not making sense. After it cools off, I will change the coil to a Bosch 12V coil. This coil had good spark when I bench tested it using an old GM points dizzy. ~1/2"
