Mercury Mike
If when you start your car, it starts, then starts to die, then runs good for about 3 seconds, then starts to die, then runs good, off and on, for about a minute, and then dies, and gas spits out the carb... does that sound like it could be a distributor problem? I have to keep resetting my distributor. It will do this about 3 times, then it won't start. I got fire in the carb once, but that only happened once. If I reset TDC, reset the distributor, 12*, it will do what I described above. I have another dizzy, from a free 200 that I got, and am rebuilding currently for a different 'Stang. I am thinking about dropping this dizzy in. The motor in the other mustang ran good, so I figure I probably won't have this problem... I figure since it tries to run when I reset the dizzy, it must be the dizzy, right? On the plus side, I got to drive the '56 F100 today, thing hauls ass! And for Christmas, I'm getting a full suspension, wheel bearings, brakes, and steering upgrade. New parts, but I think I'm gonna put a power steering kit in.
