I just installed a DSII and have a problem that I read about in another thread but now i can't find that thread.
I wired everything according to the diagram from MUSTANG STEVE site.
When I hit start, the car doesn't and the starter keeps running till I turn the ignition off.
1. I ran red wire from the ignition, where the thick pink wire was connected, to the coil and the module. Then left the pink wire disconnected and taped off. Also disconnected the stock wire from the coil.
2. Ran the white wire from the module to S side of the solenoid and disconnected the brown wire fron the I side. there is nothing connected to the I side at this time.
3. Then run the green wire from dissy to the - side of the coil.
Where did i go wrong?
Dale
Dale
