mustang652
I got an return email from the guy who does the DSII recurves on my inquiry to buy one, and he ask what is the diameter of the distributor shaft. As I don't currently have any way to properly measure it, and I taking into consideration that I had to do a little grinding sanding to get it to slide in smoothly, does anyone happen to know that info. My block is a 200 and it's from a '66. The DSII im using and had to grind down slightly is from an '81 Zepher. The second question is should I also buy a new control box at the same time or use the one I currently have.
