mysavioreigns
After much research, I am a little farther than I was when I started
I just ordered the electric H/W 5200 from Langdon's Stovebolt, and it's on the way. I'm not sure where this wire should hook up to. I've found it should NOT be hooked up to the coil, and I've heard something about the ignition switch...
This is where it gets fuzzy. Do I need to use a 10A relay? And if so, where am I going to wire that in to? Thanks,
Stephen
Stephen
