MercuryMarc
I have an adjustable temp switch that activates my electric radiator fan. I have the switch set at the lowest point which the manufacturer says is 150 degrees.  But the switch turns on when my temp sensor in the block reads 210 degrees.  I have the temp sensor switch probe placed between the rad fins next to the upper coolant intake hose, and I have also tried placing it lying on top of the radiator tank secured with a fitted piece of sheet metal.  I can't get the darn thing to turn on at a lower temp.
Is there a hotter place I can attach the probe (like on the block)? I wonder if the Aluminum radiator doesn't conduct heat as well as the block and that is why the temp sensor turns on so late. By the way, this probe is the kind that cannot get wet and is externally mounted - it is from Derale.
Thanks-
Marc in SF
63 Comet with a 69 Falcon 200 ci Six, Aluminum Racing Radiator, 14 Inch Pusher Electric Fan, Tefba Filter, and extrenal Tranny Cooler
http://mercurycomet.net
Thanks-
Marc in SF
