Hey all! It's been a while, but I am finally getting the engine work done on the car.
I originally wanted to just clean it up and put it back in the car, but a buddy convinced me to remove the head. We found a valve was getting burned up and there was a bit of play in the bearings. So, the head and block are completely broken down. I went by the machine shop today and the guy was super helpful.
Here's what I found out -
Block
Crank should polish just fine.
Block was already .030 over. He's going to go to .040.
Head
Head needs hardened seats on exhaust side.
Needs new valves
Needs to have valve guides re-worked.
Owner was a bit concerned at the spring compression that the 302 spring from Mike have. He was worried that they might wear quickly. Any thoughts?
So, based on the head, I am going to find a 250 head and have it re-worked.
Should I get new pistons or use the .030 pistons with .040 rings? Is that possible? Flat top or dished pistons?
Thanks for the help!
Jason
Block
Head
Needs new valves
Jason
