electrorc
Ah yeah thanks for the reminder about them leaking down and what not. I had let them sit in oil for like a week and then I pumped them up a bit, but with the springs having like 270 lbs of open pressure, they probably sank back down.
I dropped a solid lifter in today to just double check. Bad results, from bottom of the spring to the top:
#11: touching, 0.008", 0.020", 0.016", touching, touching. 0.044" total
#7: touching, touching, 0.006", 0.008", touching, touching. 0.014" total.
So even if you add in something like 0.030" for lifter preload, they're way too tight. Did I do that right? From what I could tell the solid lifter's pushrod seat was at about the same height as the hydraulic's.
I know the hydraulics have something like 1/8" of travel and are supposed to sit in the middle, but I'm not sure where the solid compares to that.
Edit: Finally contacted the shop. They're going to look through the specs and see what they can figure out, and I'll probably go talk to them tomorrow depending on what they say.
