electrorc
electrorc":h9b657pp said:
800 mile drives to and from college
College huh, OK. Do you have the summer to work on this or are you pressed for time?
Did the same thing to my '61 chevy while a junior at U of Iin the summer while I worked at a gas station. It thru a Rod bearing so I completely rebuilt it.
Is there any good way to check the timing chain?
The way I due it is to
1. Put a socket wrenk on the Balencer hold down bolt.
2. Rotake the crank clockwise for 1/4 revolution clock wise then 1/4 revolution counter clock wise.
3. watch the distributor rotor for how long in degrees it take to change dirrection when you change dirrection of the crank rotation at both changes.
You'll need the distributor installed for this but it does not have to be timed, any old way is fine, time it later.
Also when you due the final install of the distributor make sure by watching the valves as you rotate the engine to TDC that you are on the compression stroke not the exhaust stroke. Installing the distributor on TDC of the exhaust stroke is called 180 out because yoor spark will come at TDC of the exhaust stroke when all the gas is in the exhaust pipe.
OK, buget rebuild.
1. Definately get a valve job done on what ever head you install. The best thing for performance is a three angle valve job.
2. Get an adjustable Rocker arm setup with new push rods (all). Your best bet here is to goto Mike's page for it
http://www.classicinlines.com/products.asp?cat=38
Product ID: RAS-200-ARA
Adjustable 1.5 Rocker Assembly Details
Rebuilt adjustable rocker arm assembly with 1.5 stock rocker ratio. Fully assembled and ready to bolt on. Fits all 170/200/250ci engines.
NOTE: Requires ball and cup pushrods
Price includes a $50 refundable core charge.
Please see our Core Refund Policy for more information.
See Details for more information.
List Price: $175.00
Price: $195.00
Product ID: RAS-200-ANP
Chrome Moly Push Rods (170/200ci) Details
These non-oiling chrome moly push rods fit 170/200ci motors with adjustable rockers. For use with adjustable rocker assemblies or with Classic Inlines roller tipped rocker assemblies.
List Price: $55.00
Price: $45.00
3: While the pan is off you should Plasti gage the rod bearings. Lots of how to link out there here's one.
http://www.team-integra.net/sections/ar ... cleID=1213
Also think about a new oil pump.
Product ID: MEL-200-OIL
Melling Oil Pump Details
Melling Oil Pumps utilize the very latest in pump technology and offers the finest quality available, so you can install a Melling oil pump with confidence and pride.
See Details for Application Chart.
Oil Pump: Please Select...M65 - add (+$15.00) M65-A M65-B M82 - add (+$5.00)
Price: $44.95
4. The rest depends on what you find as you examin the engine.
I noticed in one of your bottom end pictures there was some coolant of the rod cap, how did it get there?
I'd like to get disc brakes up front.
The engine will probobly use most of your 2k budget. Disk Brake will cost around 500 and you will most likely need new wheels as well. My advice would be to save the disk brakes for next year and do a quality rebuild on the drums you've got for now.
Oh and by the way it's is obvious you will need one new lifter. If you can use the new lifter to "repair" the old one that would be best cause the cam and lifter wear in together and a new one may flatten the lobe.
