Felpro Head gasket for Crossflow?
Does anyone know if a Felpro head gasket is available for the Aussie ford crossflow six cylinder?
Do the early non crossflow gaskets fit? I would expect there to be one for them as those engines were used in the U.S.
I need one desperately as my engine pushed the ACL gasket out into the pushrod gallery on the weekend!
HI MARKZE,
i dont know if felpro do a headgasket.what ACL gasket were you using.is it a normal ACL BH100MT . There are a few different gaskets you could use.ACL now do a "COPPERHEAD" head gasket.
this is available in either 1mm or 1.6mm thick.
P/NUMBERS BH100CU10GTR or BH100CU16GTR.
AA GASKETS (permaseal) in aussie also do a "GRAND PRIX " gasket which is also a good performance gasket.
P/NUMBER BH100GP
TRY WWW.ACL.COM.AU or WWW.AAGASKETS.COM.AU
cheers dave 67xr6
I have used a Permaset Premium Grand Prix gasket on my old hump since 1997. The cross flows are 38 mm wider than the non-cross flows, so no US gasket fits...yet!
I'd go for copper, and use good preventative maintenance to ensure the galvanic action doesn't pit the cylinder head. Some of the rare US alloy blocked 225 Slant Six Chrylser engines used to corrode by pitting when copper was used.
The best one I've heard of is Araldite. If your headgasket develops a leak, you shouldn't have much problem removing it if you use a port-a power. Just a crazy thought... :!: Turbo guys in the States with Cosworth headed 2.5 (Pinto/Lima) OHC SVO four cylinder blocks have been doing it for years!
The Falcon six needs five bolts per cylinder like a Ch**y small block to keep the gasket stable. The Ford six has a stone cold number one cylinder with a water pump, and very little support on the true left-hand side of the block, even less than the pre cross flow 'cause the head bolts are that much further away.
I think there is heaps of thermal stress between an alloy head, cast iron block, and cold front end, hot back cylinders, and cool left hand side. All the exhast heat is on the right hand side, and I think that's what makes the block deck face buckle. You see it first on the propane fueled engines like mine, before you get it on turbos.
ON some engines you torque one side differently to account for those kind of things. Maybe the Ford six is a case for that.
Thanks for the info.
I have settled on an ACL race series gasket which uses a stronger fibre material and a stainless steel bore binder.
I am having an o-ring groove cut into the head which is easier than removing and stripping the whole engine.
I just thought I would try to track down a Felpro as I have been talking to a guy who uses them on Touring car engines and he claims they seal as well as an oringed setup.
They have a special bore binder ring built into them already which leaves and impression in the alloy heads once they are removed.
