After re-reading many posts and the Sticky on the different heads used through the years and the effect of the modern composite gaskets, I have a simple question.
Were the thicker composite gaskets used OEM in the later years of the small six?.
Also, since the heads are interchangeable, are the gaskets all compatible?. I have a couple of OEM steel gaskets and wonder if I could I use them on a later D7 head? . I thought the gasket's cylinder bore sizes will be wrong(?).
Thanks, Powerband 8)
