?????????Heads?????????????
This is a question that was ask. But I am still wandering. I have a 66 Mustang with i6 200. The head is broke on the last bolt hole for the exhaust man. I have a 83' i6 with trans on my car port that someone left me for parts. I know about the harden valves and the large valves. But very Confused about compression. I know it with bolt up. Is it better to repair the old head or install the 83 head. Its no very clear about change it over. Milling and gasket size? What is the best and easy way. Just trying to make it sound better. :?
8) i would use the 83 head, mill it like .050, and have the vvalves done on it.
Howdy Daniel66:
If you haven't already read the sticky post at the top of this forum please read it. If you have, you might want to reread it.
In summary, the '83 head will have several advantages over your broken '66 head. The down sidesof swapping to a late model head are, a larger volume chamber on the '83 head and a thicker aftermarket head gasket gasket.
Measure all critical dimensions for yourself. In all cases it is best to measure both before and after machining. The following is a good generality, but with generalities, there are always exceptions. With FoMoCo, "Always" and "never" are dangerous words.
The stock '66 head chamber volume is aprox 52 ccs.
The stock '83 head chamber volume is aprox 62 ccs.
.010" cut of the head = slightly less than 2ccs.
Late heads can be safely milled a total of .090".
Stock OEM steel shim type headgasket measures aprox .025".
Aftermarket composite type head gaskets measure aprox .045" to .055" compressed thickness.
My advice- Use the '83 head, and have a valve job done that will include new valve stem seals, a three angle performance valve job. Mill it .025" to compensate for the difference in head gaskets, and .050" to compensate for the difference in chamber size. Use hardened washer on the head bolts on re-assembly. This should equate to about a stock 9:1 CR or slightly less.
Now you're ready for an electronic ignition, a bigger carb and an improved exhaust system.
Enjoy the ride.
