TucsonHooligan
I have a 1966 200 block with a later square log head on it. I need the drivers side heater hose output, but everything I've come across is the same as the passenger side: a threaded brass nipple that screws directly into the block. On my block, it appears to be an open outlet with two threaded mounting holes diagonal from each other. Wish I had a pic, but my camera is kaputt. Anybody know what year I need to look for to find this thing? I imagine it as a bracket with a centered nipple with two mounting holes that match the block. Does this make any sense to anybody? Does anybody have one? This is the last thing I need before I fire up the motor for the first time. I suppose I could make a blank plate for it, tho eventually I'll need it so I don't freeze in the winter. Thanks for the help!
