I think I went a little off topic in this thread with those doors lol
I might need some more suggestions from you guys.
So I put everything back together in the engine (new adjustable rocker arm assembly and new replacement carb from Redline Weber). Adjusted rockers to zero lash plus 3/4 of a turn.
Carb was set up to idle screws 1.5 turns out with following jets per Redline:
Mains 145
Air corrects 170
Idle 55
E/t F50
70 double pump
Was trying to start the car yesterday and completely failed - at the beginning it was trying to start, but at the end of the day just didn't want to start. I think I ended up flooding the engine.
Decided to check the compression with new rockers. Removed all spark plugs and when I was checking compression on the first cylinder, cylinder #6 just spat up a bunch of gas from spark plug hole lol. So yeah, flooded....
Compression was good:
1st - 175
2nd - 170
3rd - 165
4th - 170
5th - 160
6th - 170
So I assume that kinda scratched possible problem with valve adjustments?
Checked the battery - was at 49% charged, so got it charged overnight.
Was trying to start it again today (after letting it air out some of the gas from the engine). It started briefly, but kept dying on me - had to hold acceleration to keep it running. Eventually it died again (when I let it go). After that, wouldn't start again.
Car ran before with faulty carb (dumping too mush fuel) and regular rocker arm.
Spark plugs are fairly fresh (maybe 40-50 miles on them).
Ignition was roughly set to 8-10 degrees advance.
Distributor gets power and I removed spark plug wire and checked that there is spark while cranking.
I'm a out of possible options what to check/do now. Not a fuel delivery problem, as it definitely gets gas in.
My options are: my DUI distributor is not giving full spark (Dyno Module?) or try to put back my non adjustable rocker arm assembly and try starting it again. Maybe I did mess up something with the valve adjustments....
Anyway, any suggestion or direction to move forward would be greatly appreciated!
