Most every mechanical fuel pump I've seen doesn't have any bypass, they just build pressure against the diaphragm spring. If there's little to no fuel flow, the pump arm just keeps moving independent of the diaphragm, so there's no need for a bypass.
Looking at the old pump, which was the small non-filter type, it's got a slightly different shaped arm than the one that's in there. Things that make me go hmmmm.....
