Hi,
I've been picking up great info from this website for a while. I'm sure this will be an easy mystery to solve.
I'm rebuilding a 200 from a 1981 Fairmont to drop into my 65 Falcon. With cylinder 1 at TDC, the original damper didn't line up with the timing cover mark. Visually it looks like maybe the rubber has shifted. When I check the damper from the Falcon's original 170, it does line up with the timing cover mark. So, I bought a replacement from the Damper Doctor. It has the timing mark at a totally different location. There is also a wide notch that I'm not sure what it's supposed to be (at the 8:00 position). Here's a picture of the three different dampers
I'm assuming the 170 damper is correct and the others are wrong. Is there something I'm missing? Did something change with the basic engine construction over the years?
Any help here is greatly appreciated.
Thanks,
Steve
Thanks,
Steve
