... questions.:
First, is the Carter YF a single barrel?
> YF Carter like many carbs has many variations. One version was used on the Fords -(MAv/Com/Stang/Granada...?). Good running later - higher CFM carb widely available not expensive.
How user friend is the Holley 2300? Think of someone that has no carb experience, zilch, nada. Willing to learn though.
> 2300 is generic name for Holley 2Bbl 2300
series' Two most popular versions are the 7448 and 4412 versions, 7448=350CFM and 4412=500CFM roughly. Both are not built for stock small sixes in their flow ballistics but do very well with modified engines and are widely available used and new and fairly inexpensively.
What adapter would I need to mate the Holley to my 200cid? Where can I buy it? A link would be great.
> The Holley 2300's have familiar
half of four barrel 2BBl carb base. Multiple vendors sell adaptors from 2Bbl to original 1Bbl opening on head. Even more sell the Weber-Holley/Weber
small 2Bbl carb base to original 1Bbl port and can be used with a second adaptor (
H/W to Holley) to fit 2300 but best solution is "direct mount" which requires machining and some minor mods.
> YF's vs 2300' on Maverick 170: , YF was good running - smooth idle - decent performance and 2300/350 on adapter was good running - smooth idle - max performance with terrible gas mileage and eye-watering rich @ mid throttle.
Common alternative is aforementioned' Holley/Weber 5200
PROGRESSIVE 2 bbl more suitable to small engines. There are so many variations of the 5200', seems more
issues than with many others...
HAev Fun
2300 with two adapters on D7 modded head on 170:
Two YF's Maverick and an unknown application:
