texas_rat_trap
I'm runnin 2 Holley 94's on my 223...I was told to run at no more than 2 psi of fuel pressure. I'm also runnin an electric fuel pump with an out put of 5.5 - 9 psi but have it going through a fuel pressure regulator then splits off to a Y fitting with a JEGS fuel pressure gauge which shows little to no psi when running engine. My question is when I try to start the engine it fires right up & runs for about 15 sec. then shuts off like it runs all the fuel out of the bowls then the fuel cannot keep up anymore. So I keep bumpin' up fuel pressure 2, 2-1/2, 3, 3-1/2, does same thing but when get to 4psi wants to run like a bat outa hell..... but then fuel starts pouring out the top of the carb. Also on primary carb at higher fuel pressure one of the venturis I think this is what its called the arm that sticks out centered in middle of bore, well this thing leaks also but is the only one that leaks out of 4, 2 per carb...what causes this arm to leak. Please anybody familiar with these Holley 94's
[/b]
