Ok, my last posting didn't draw much interest but here is the deal. I know you inline expert will help me get this care on the road.
The car will not stay cranked (sort of) the car specs are listed below:
65 Mustang 200 block and head (new valve job on head)
Stock cam & pistons
Holley 2300 manual choke 2bb
Duraspark ignition with msd blaster II coil (stock module) .50 spark plug
Dual headers (STILL JUST HAVE HEADERS CAN I TIME WITH THAT???)
A/C (in Tucson a must)
With the choke set almost closed it crank and I can then open all the way.
It ideal at 2000 rpm according to tack (I THINK THAT IS TOO HIGH????)
This is what I have done so far: I closed both metering screws on the Holley and then turn those 2 full revolutions.
Then tried to reduce ideal but it starts to cut out on me.
My timing mark is about a inch away from the WHOLE Timing block on the timing chain cover (Toward the Passenger side) When I try to bring it back toward the block it shut the car off.
I NEED HELP getting this car back on the road.
Stock cam & pistons
