Would you please take the time to measure the DC resistance of the primary of the Inferno coil.I just confirmed with the company that the Inferno coil does want a full 12v.
Sure there are many many people that don't hook up the White Wire and have no issues in starting if that works for you to no need to change it. Getting the Coil the right amount of Voltage is bound to help with the engine Idle some, especially if the Weber Carb is a bit on the rich side right now. However I have not tried to use that Inferno Coil, have only used all the stock MotorCraft spec parts or upgraded to the NAPA Echelon Parts for my DS II swaps including the Coil for my conversations and its more than adequate for a stock to mild Performance Engine for street use.Since I was having trouble starting the car without the timing being advanced so far, I didn´t think retarding it would help so opted out of the white wire. I´ll hook it up now and see!
I just confirmed with the company that the Inferno coil does want a full 12v. I hope that completing the wiring as per Mustang Steve and giving it that extra juice, maybe my starting and rough idling problems and other things will improve.
With the AFR gauge hooked up, I´m excited to see what´s going on. One thing I did was to gather all of the Weber DGV settings mentioned on this forum, some 20 or so, and get the average jet size for each jet. I´m kind of making that my starting point now, especially with the idle circuit. Not a fool-proof method, but I hope it gets me in the ballpark. I´m at 2000 feet above sea level and all of our engines breathe differently, of course.
I had to stack some washers to align my pulleys on install, and I think they are good. The squealing is only during warm up, it seems. I´ve cleaned both the pulleys and the belt, used belt dressing, but it still squeals some. I might try roughing up the grooves next with some sandpaper, but don´t think it´s a major issue as long as I don´t overtighten the belt. I´ve seen on other forums where using a 100 amp alternator can do this on a single-pulley setup. Oh well, will get to that in time...
Cheers again, Bubba!
Tim
If you add another .2 ohms for wiring without the pink wire, the total resistance through the primary side of the coil is about 1 ohm.No problem: I found .8 ohms on the coil, nothing connected to it and subtracting .1 ohms from the probes.
Your interpretation, pmuller9?
Cheers,
Tim
Yes, the attached diagram shows the correct placement of the ballast resistor and the correct wiring between the starter solenoid and coil.Thanks much for the info, pmuller9! I could wire that in.
One wiring scheme I had been looking at was the one i´ve attached here, which illustrates one placement of the ballast resistor. Does the diagram coincide with your thoughts?
It shows the resistor between the ignition and the coil, then another wire from the coil to the I post on the solenoid.
Does this mean a serious omission in Mustang Steve´s diagram?
Let me know what you think and thanks again!
Tim
