Hi Tim I went looking numerous places including the Davis Unified site for their Coil Specs they had nothing useful hopefully they gave you some of it with the coil when you bought it. So the info is kind of hard to come by, kept looking found most of the useful info on Summit and one other site, X2 I fully agree with pmuller9, after on the last site I did find the 1 Ohm Ballast Resister being recommended by Davis for street use of their Inferno Coil along with their Dyna Module (this is the old MoPar type Module) for use with a Duraspark II Distributor so that should be a good place to start over using the stock Pink Wire Resistor. Davis states "that for street applications, a 1 ohm resistor must be used which will limit maximum rpms to 7000". For strictly racing use and up to 10,000 RPM no Resistor is used. Davis states "The resistor is used as a precautionary measure to protect the coil and module from premature failure on long periods of running time".
Some of the other info I found on the Inferno 31722 Round Canister Coil is 2.50 inches diameter and is made in the USA in Tennessee, Davis states that its suppose to be "a direct upgrade from the original Duraspark II coils". With the above Resistance issue I have questions about that being true. They are suppose to not need the Resistor yet I found one person who said he burned up two of these Inferno Coils first one in a one day of use the second one in two weeks using the stock Pink Wire Resistor Wire. So after again to keep this coil working right I think like pmuller9 that you will need to find the right External 1 Ohm Resistor unit and then disconnect that Pink Wire removing it or running a new wire to the new Resistor. According to Davis the coils Primary Resistance is suppose to be 0.4 to 0.9 ohms when measured with a Volt / Ohm meter. Also make sure that you have some good really grounds from the Battery to the engine block, from the Block to the Chassis, and maybe even an extra one from the Block to the body. Best of luck
