Heh everyone, How much more oomph can I expect to see when I install the 250 vs. 200 ? The 250 will have 255 pistons, and a ported and polished loghead, that has been modified to accept a 2 barrel directly without adapter. It will also have headers and 2" dual exhaust. I'm not sure which cam I should use ? Would the 264* clifford from my 200 be the one ?(rpm range 2000 to 4500), or should I look at another manufacturer that makes power at lower rpms ? Am I correct in assuming that the 250 will not turn the rpm's of the 200 ? I will have a C4 tranny and I have 3.20 gears. I'm also assuming I will need to get a different torque converter with a higher stall speed. (what would be a good tc)? The 250 is out of 75 comet.I will try to put a picture of my ride up. It's www.hometown.aol.com/homerlapier/myhomepage/index.html
