Hey guys, I'm a total newbie when it comes to my 67 200 Mustang. I was tried to start restoring it a couple years ago but then life happened and it sat for a while. I finally found some time to start working on it again and one of the things I've read is an easy upgrade is electronic ignition. I put in Pertronix Ignitor I and the Flamethrower Coil after realizing the my starter solenoid was shot. After the install the car fires right up but the idle is ridiculously high, like I would be afraid to shift it into gear it's so high. I hadn't touched anything else except for checking the plugs, putting some Marvel Mystery oil in each cylinder (because it had been sitting a while), and doing an oil change. What could be causing it to idle so high? And where should I start with trying to get it down to a reasonable RPM? Please remember that I am a total newbie and a lot of really common things that seem reasonable to a seasoned car guy would be totally over my head. Thanks!
P.S. I searched for this topic and only found responses for rough idle after install. So sorry if this topic has been covered before.
I will definitely check the idle since that is something I think I can easily do. The timing change sounds a little more involved from what I've been reading. So to start with the idle mixture, I looked at my carb and I could only find one mixture screw... I found out through some online research that my carb is a Holley 1940 1bbl. Is there something I'm missing?
