'68falconohio
I've been working on my cylinder head. E0 casting, bye bye log.
1.75/1.5 portflow valves(CI), 30* backcut on intake...have not ordered yet. I'm going to unshroud valves enough that they clear but want to keep the combustion chambers close to stock size prior to shaving due to CR goal of 9.3:1.
Need some advice and insight on the intake manifold and porting. Here's what I'm seeing and a little confused as to which direction to go.
The surface in red on the second picture is at nearly a 45* angle to the general direction of the intake port. I'm contemplating making the runner of my intake manifold the size of the cardboard tube in the second picture and 'filling' the area in red some how. With zero experience with porting or desigining intakes, this 45* degree angle looks like it's going to kill airflow.
The other option instead of making the intake runner the size of the cardboard tube is to make it the full size of the port at the mating surface and to have it come off of the head at the same angle as the cardboard tube is shown. Am I worrying too much about the angle of the area in red???
I'm looking for a way to fill the area in red if I so choose. Is there a high-temp epoxy that can be used to fill this area? Or a better idea?
I realize that these pictures don't really tell the story but it's extremely hard to take meaningful pictures of an intake port, even with lighting from the combustion chamber side.
On another note, I think I'm going to step the primaries on my headers also. When I milled the exhaust mounting flanges off, I found the exhaust ports have an even smaller cross sectional area now. I'm going to run 1 3/8" primaries for (unknown length as of now) and then 'step-up' to 1 1/2" in an effort to keep the velocity from dropping a lot when the exhaust goes from the small port in the head to the primaries.
Note, I have 'The Scientific Design of Intake and Exhaust Systems' and am nearly through it. I need to read it again, and possibly another time.
Any advice or voodoo magic tricks with fluids is always greatly appreciated.
