All Small Six Intake Port Divider with 2 Barrel Conversion
NickC
Hello FordSix,
I finally finished my winter project: a custom-made intake port divider and 2-barrel conversion.
The engine is a 1978 large log 200ci installed in my 1964 Ford Falcon Futura (3-speed automatic). I video recorded timed acceleration tests and repeated them under three different configurations:
  1. 2-barrel carburetor with 2:1 barrel conversion
  2. Super Sniper 2300 EFI with 2:1 barrel conversion
  3. Custom intake port divider with 2-barrel conversion
Configurations 1 and 2 were very similar, with no statistically meaningful horsepower difference. However, the Sniper completely solved my vapor lock issues and makes cold starts effortless, even after sitting for weeks. I would recommend the Sniper 2300 for drivability, though it does lose a bit of the 1960s charm.
My only complaint about the EFI is that the touchscreen is somewhat sensitive and tends to jump around due to dust and debris. My Falcon is a convertible, so it is exposed.
According to my analysis (with ChatGPT assisting in calculations), the intake port divider combined with the 2-barrel conversion resulted in an estimated 9.16% average increase in net traction horsepower.
I used the “Physics Toolbox” app for GPS and elevation measurements. The video frame rate was approximately 0.033 seconds per frame (30 fps), which limits timing precision somewhat. The Physics Toolbox app logs at 1 Hz, which is not ideal for high-resolution acceleration analysis.
The test road was approximately a 3% uphill grade, and speeds were limited to about 70 mph. The Falcon retains its original 1964 3-speed automatic.
Interestingly, the calculated net traction horsepower gain was more pronounced at higher RPM rather than lower RPM. Given measurement limitations, there is some margin of error, but the improvement appears consistent.
Subjectively, drivability is noticeably smoother and more responsive. It is definitely quicker — though not quite Mach-E GT quick.
I am very happy with the conversion.
Enjoy the photos.
Other notes: Compression and leak down tests before the top-end rebuild were adequate so I did not resurface the valves, head, or block. I did replace the valves, head bolts, thermostat, and leaking valve seals, but not the keepers or springs. I performed a mild polishing of the ports. I power washed and glass bead blasted the head rather than a more appropriate and typical approach.
Here are the images :)
I machined the log head as shown and used a little JBWeld to backfill the driver side rear of the racetrack machined surface. There was ~1-2 mm of solid material left, but I wanted more for the gasket. I sealed the gasket only to the head side. The four hex bolts used to secure the divider were measured and spaced appropriately so they do not interfere with the gas flow. The divider is removable from the box and is angled about 15 degs off perpendicular to direct some gas flow to the first adjacent intake runners.
And for fun, I machined part of the symbol for entropy onto the box, symbolizing "Control Entropy".
Good job (y)
I do not think that that gasket maker is rated for gasoline/alcohol, but I could be wrong. keep an eye open any leaks down the road.
THE BOX ! = excellent simple in form concept', followed through to it's function.
the 'Box' solves a couple of dimensional problems, simplest one being the box raises larger carb/FI flange level to clear valve cover . ( placing fuel bowls away from headers ). Smaller footprint on intake runner makes it simpler . Also the use of pontoon fastening to the manifold allows simpler intake sealing without fastener complication . I'll take one !.
I use 2X1 adapters and currently also working out a 2Bbl conversion. With angle grinder milling , I opened a D0xx head for experiment. The runner sides where sealing required, is supplemented with epoxy. With limited resources , I had a "concept of a plan" to weld C-channel back to back with required @ 3degree wedge for a 'box'. - ( all look like nails if you only have a hammer) The pontoon fastener bosses of the 'box' may be best new idea I've seen. A forum member helped create file for 'printed' wedged 2bbl adapter but haven't found suitable material.
Permatex 'Ultra Black RTV' claims to be "Oil Resistant" but only "Motoseal' and similar claims to be "Fuel Resistant" AFAIK . Regular RTV not good , a quality epoxy has worked.
Mr. Gasket Weber/Holley converter riser has minimal sealing at fastener bolts, the fastener wells can be epoxy filled for better confidence.
Very nicely done! Without the means to machine my own box, I created a redneck version by stacking phenolic spacers. I like the looks of yours better than what essentially looks like stacks of wood on mine! LoL
Hello FordSix,
Enjoy the photos.
Great project with a detailed description! Did you settle on configuration 1? Which 2-barrel carb did you use?
@powerband , I’m not sure how you post your photos, but they pop up in a “postimg.cc” site. Sketchy adds and wants me to download image. Is it just me??
THANKS > was not aware of this situation at all ! . the hosting site doesn't show me adds or popups. "postimages.org" has been convenient and hopefully some help here. Like the old 'Photobucket" hosting site , probably used an add-free intro period to acquire accounts .
I'm only on a few forums but notice a few have direct links from picture hosts blocked and it takes a few steps to post and not from a hosting site, uploads from me - JPG's or similar - not links.
I had loaded a few pics on FSP personal media page , haven't used .
... suggestions ?
And when you scroll down it’s purely clic bat. It is hard to zoom in on details as well.
I use my phone mostly, sometimes desktop. I click the attach files tab ( to the left of the post reply tab. It gives me the option to choose where to get the picture I want to post and the select the photo, click ok, or now a ✅ , and that’s it👍
thanks for the feedback and image of the problem with posts.
That's ridiculous, it's getting impossible to withstand the constant commercial barrage from all "free" media, ... back to the written word !
  • Like
Reactions: DON
I wonder if the browser being used affects add insertions from host sites ? . Lastly asking if anyone does not see all the trash adds on pics I've posted.
Done for now, lets get back to business of 2Bbl's etc.
thanks
... suggestions ?
No, need to use hosted images any more my 2 cents. This site now lets you upload and insert images right here.
thanks
I use duck duck on an iphone
BTB👍
Thank you! I appreciate the comments and good luck with your project. Cool pictures! There are some carbon fiber FDM printing materials that are OK to print and use temporarily, but they are not very cost effective. using your printed part for sizing is great, then move to aluminum once you have the sizing correct!
I always have the same probably stupid thought whenever I see someone custom crafting a way to get more air into these relatively restrictive cast-in intake manifolds. The front and rear cylinder intakes are especially far removed from the single centered intake, and tend to be starved for air and gas. Has anyone ever used the plugged openings in the ends of the log to let some more air in? Having that sort of plenum sitting up above the log is halfway there already. Run some tubes from the front and back of that plenum above the log and U-turn back into the log ends. Yes, it's hardly the most efficient path with those bends, but it should be better than no path. Maybe it would work well enough that the center inlet opening wouldn't need all that machine work to enlarge it, and it could be more or less a bolt on kit. Let the laughter begin...
