1. Flexplate to crankshaft, oil resistant sealer -RTV sealer on flexplate bolts.
2. Rf headbolt, RTV sealer all the others are blind holes, no coolant present, so no sealer needed if studs are used, other wise moly lube on headgasket bolts except the rf.
3. Trans & Bellhousing, none required.
4. Rocker arm pedastal, none.
5. Converter to flexplate, red loctite.
