MandarinaRacing
Hello all.....I'm really bummed right now...my car simply does not cooperate sometimes...I took the dizzy out, when I tried to fire the engine it just won't start. My guess is that is 180 off. So I took the #1 plug off, stuck my finger in the hole and turned the engine by hand till I felt pressure, the I aligned the mark on the balancer to the TDC mark. The gently tried to put the distributor in with the cap pointing towards the #1 tower put every back together and...nothin...tried it several times, and in 3 different positions, and nothing. I also took the plug and layed to rest on the block and bumped the engine and the plug fired, so I know that theres power getting to the plugs. I checked the wiring and everything seems ok. Then I even tried to do it with th VC off so i could see the valves closing to indicate TDC.....and still nothing. I also checked that there were no leaks PCV, carb base, etc....it's really puzzling me and I'm outta patience and I'm pretty tired.....maybe someone will see something I missed...the car was running fine, I really don't know why I took the damn distributor out......
PS: sorry for the rant....but I know you guys will understand
Alex
Alex
