After over 6 months waiting at last my, foam finer filter finally arrived. I went with the 9 by 3 inch because my nine by two is not enough to flow air properly at 4800-5000 rpm with 250 2V (intended rpm).
Checked again last night and I have less than 1/4 of an inch between flat 4 TD hood and air cleaner with the two inch filter. The only way I can get the 3 inch on under the Hood and keep it a sleeper is to get rid of the 1/2 inch spacer. (cant put on scoop because of stepped uneven surface on hood). Removing the spacer still wont be enough so Ill need to cut away the top of the manifold and insert a thinner spacer (2 or 4 bbl) welded partially down into the manifold with tapped holes for the carby to bolt directly on. I think Ill still have about 1 and 1/4 inches from the underside of the spacer for the fuel to exit into the runners.
I think this will be OK. Just thought Id check with you all first?
