Mod's for an 84 LTD
I was wondering if someone could help me cos i'm a bit stuck on how to start my project and where to start.
I've got an 84 LTD EFI stock standard and I wan't to pump it up so it will be quick but also drivable everyday. Economy is preferable as i have to travel quite a few klms a week but the power of the thing at the moment just doesn't cut it with the 3 speed auto and lazy diff gear. I was hoping to change to a five speed box and modify the cam, exhaust and diff. What would be a good combination? :)
I would say go the 5 cogger first. Look for the Toyota steel case conversion as a full kit, but used from a wrecker (cheaper by half). The steel case boxes are strong and serviceable. The T-5 needs some mods to the shifter to take punishment, plus it may be dearer to start with. You will straight away get the economy of the manual.
Working on a "suck it and see" basis, the engine is next, diff last. Talk to Crow and see what cam they suggest for power and economy. Whether you run with their "full kit" or just buy the cam from them and all the doo-dads elsewhere, expect a price hit. It's not desperately cheap. At the same time, you would be assessing the shape the rest of the motor's in. Good headwork is pricey, and should be attended to before a cam is installed, if needed. You might need new rings, hopefully not a rebore; maybe new bearings and a kit for the oil pump. This much work could run to $2K parts and labour, realistically.
But as I said, the manual swap would be the first thing. Enjoy it!
Regards, Adam.
The thing with the gearing is that an automatic LTD with a six needs more gears than a V8...it's doing more work, after all! I give you two options (just like the gangster in Home Alone!). Take the easy road and get a Castlemain Rod Shop 5-speed Toyota gear box conversion, or optionally the T5 manual from an S-pack XF sedam/wagon/ute. BW diffs are on most big Oz tanks. As long as its 25 spline axle with a crushable spacer, you can shove in the lower 3.23:1 gears or even Valiant/XA 3.5:1 ute gears or 3.45:1 pre EL gears, and do the clutch master change and peddle changes. The electronics for each model car were dedicated, so you may have to change them, but you should be able to wing it with no changes. I don't know, I don't do electronics. You'd need to get the RTA to check it or get an engineers advice, but that would be the easy route to getting some life into the old girl!
But there is another option, if youre a glutton for punishment:-
(Don't read this unless you are into keeping the car an automatic)
What I've been doing with my 84 XE is fitting a non-electronic American AOD 4-stage trans to it. If you have a local Ford V8 engine importer, grab a 302 EFI trans off on non-4WD truck or sedan/Mustang. Can't be electronic! The Americans think that it has a nasty throttle valve, but it is not as bad as the old Borg Warner 40 kickdown. It is fairly heavy (38 kgs more than the BW 40) but it is strong on a six, and only needs an adaptor to fit it. You use a 351 flexplate with no balance weights, and a 351 LTD spec drive shaft and starter. The V8 guys are starting to use them on their 351 Cleveland XY to XE cars which came with FMX's, and they are easy to fit on them. It is a modern day FMX trans with no electronics but it does have a lock up clutch. The Mustang torque converter is quite loose, and with a set of 3.45 or 3.23:1 gears, it would go well. It's just a strong as a BTR LE auto (EAII to date) but with no elctronics to get in the way. Often, the Aussie importers hear about its bad reputation being V8's and can't get rid of then cheap enough. As long as your not hammering them in top gear, they are a good trans.
Here's what I did:-
1.Do a Google search on the internet, get all the info on AOD transmissions,
2. and then grab an old FMX trans with 351 flexplate and the metal sandwitch plate, some alloy tooling plate 10 mm thick and 470 mm square, and a trashed auto 4.1 block, with the crank still in place.
3. Make a template of the FMX bell housing, which is the same as the AOD, and transfer the bw 40 bellhousing pattern on it.
4. Then get a machine shop to trace the patern out in 9.5 mm steel plate. Then place a steel 9.5 mm plate on the crank the pace out the flexplate to where it should be, and use the 4.1 BW 40 sandwitch plate and 351C /FMX sandwitch palte on each end.
Thanks for the advice! I think i'm going to go the five speed option but I have one query. Is the shifter going to be able to fit in my centre console as the interior is in top nick and I don't really want to ruin the look of the cabin? With that in mind would the T-5 or Toyota box be any better than the other?
I've been inspired by the amount of enthusiasm on this site and i have a feeling i'm going to be a little lighter in the wallet department for a little while!!!!! I'll keep you all up to date. :lol: :lol: :lol: :lol:
congrats on being a proud LTD owner. If ur anything like me when you sit in the car time goes back to 1984 and ur the king of the road, looking down on all the commoners..lol.
Anyway good luck with whatever u do to the car.
p.s. if anyone calls it a fairlane u set them straight.
"its an LTD." <<<<< deadpan look on ur face
