mounting a 200 on engine stand question
2Blew2B
I pulled my motor and want to mount it on a 1000lbs stand but I do not want to remove the presure plate and clutch. I bought #8 blots 3/8" X 5" to keep it from hitting the persure plate but does anyone know if this will hold???
I'm not sure if that will hold but I was able to hang mine with the flywheel on still ended up taking that off 2 once I decided to take the engine all the way down. I hope someone else can tell you better than myself.
