Sorry I I do not know for sure about the 250 - Main bolts.lavron":3fgqufqe said:drag-200stang":3fgqufqe said:You are doing great work, looks good.
Thanks.
Just to confirm, are the 250 and SBF (or which years/engines) main bolts the same size? I need a studded main bolt for my oil pump pick-up tube.
See Ya,
Mike
I see.lavron":27t1lta1 said:Just to confirm, are the 250 and SBF (or which years/engines) main bolts the same size? I need a studded main bolt for my oil pump pick-up tube
chad":n4la2ud3 said:Did you hafta buy the whole set just for the one.
bubba22349":1js473fd said:You should be able to use the 5.0 / 302 main bolt. The 5.0 with its rear sump pan has a stud for the pickup tube support. Good luck![]()
chad":1js473fd said:aw, gosh, U do all the hard wrk, Mike.
drag-200stang":26frbph8 said:Oops, I saw arp and thought studs
Speedmaster is absolute crap. Use the stock bolts, return the studs.lavron":1fbz4xzb said:drag-200stang":1fbz4xzb said:Oops, I saw arp and thought studs
Well I went ahead and ordered the studs, not sure if Speedmaster stuff is any good but ARP doesn't offer a set for the 250, hopefully studs will be an upgrade over stock bolts irregardless.
Also, if nothing happens the block is finally going next week to be bored, decked, balanced and the Aussie pistons pressed onto the 2.5L HSC/OHV rods. I will get there eventually :roll:
See Ya,
Mike
Real nice ta meet ya in this new way!lavron":3tkm7s79 said:
chad":31d1r0io said:I'm most interested in ur suspension mods (any way to get quality, performance, affordability) is of interest to me.
Did not C enuff detail to C the air bag set up, camera moved too fast over those details.
chad":3qd5h0lr said:I think U said U will use the Ford 2.5L HSC/OHV Connecting Rods to zero the deck w/o a mill pass.
Did U locate a piston ("My Budget 250 build") for this combo? What is it? How far "dwn the hole" now? What duz the head cc out to now (or should I say nxt month, LOL)?
chad":5mjc8nb6 said:OK, head spinnin a lill right now (CR, quench, con rod, piston, rod to stroke ratio). It takes me awhile.
Archive will eat this info for next round ina few yrs. I need 200K mi to let it sink in and raise the $ both...
Thank you.
