Mustang_Geezer
All I have to do tomorrow is set on the valve cover and install the spark plug wires and she is all ready to install!!
Heres a few pics and description of what I've been working on all winter,
Short block that I completed last weekend after I installed my ARP head studs.
FSPP double roller timing chain & gears so I never have the stretched timing chain again!
Spent a lot of money on the head this time around! Shaved more off the head for a total of .080, Installed FSPP PC valve stem seals, Stainless backcut 1.75" intake & 1.50 exhaust valves and they also did a LOT of work opening up the bowls to match the bigger valves, flowing the exhaust runners & milled the bottom of the valve guide off where it protrudes out into the bowl.
Compression ratio is 10.9:1
Reworked roller valve train & remachined Cliffy chrome moly pushrods.
Closeup of the Holley 500 cfm 2 Bbl....went from #69 to #73 jets (to start with) because we hope it can use the extra fuel with the much improved head and compression!
Completed engine with Jet Hot coated parts!!
Heres a complete parts list,
1978 200 6 bored .060 over (206 c.i.)
Block decked .040
Crank ground .010-.010 undersized
Rotating assy fully balanced
Resized rods with 302 ARP rod bolts
2.3 L hsc Tempo "flat top" pistons
FSPP 7 qt deep sump oil pan w/crank scraper & windage tray
FSPP "Hi-Po" balancer
Permacool electric fan
ARP head studs
10.9:1 Compression
Head/Intake Modifications
1980 head milled .080, fully ported & polished
Clifford double valve springs
Clifford hardened locks & keepers
Clifford port divider
Custom intake manifold
Holley alcohol injection
Custom ram air
K&N air filter
160 degree thermostat
Cam & Valvetrain
Clifford 272h hydraulic cam
Clifford chrome moly pushrods
FSPP Stainless/backcut oversize valves (1.75" 1.50")
Rocker arm specialist roller rockers
Ignition
1978 Ford duraspark distributer
Accel 8.8 plug wires
Accel U grove plugs
MSD blaster 2 coil
MSD 6A ignition control box
Exhaust System
FSPP jet hot coated dual out header
1966 "K" code dual exhaust system
Dual Dynamax super turbo mufflers
Drivetrain/Suspension
1968 valve body
B&M transpack
Shelby traction bars
I honestly dont know what else to do to it......the plan was to get 225HP naturally aspirated and I think I'm close!
I am planning on dynoing it this summer to see for sure!
Special thanks to Mike at FSPP for helping me out with all the parts!!!
Later,
Doug
