salty_monk
I've been reading a lot of stuff on the forum (thanks for that) & on the TFFN/register & am gradually getting more of a knowledge base on what I have.
It's a 1962 Ford Falcon (Pic in the "intro section" of forum).
On further research (never met previous owner as I got this from a friend who took it in trade) it has a 200ci 7 bearing 6 fitted (I believe, more on that later) with a 5 lug V8 rear end.
3 on the tree transmission (no synchro on first).
Please see pics of the engine install... messy but it runs....
Full album of pics is here http://s6.photobucket.com/albums/y247/s ... %20Falcon/
What engine do I have? I believe it is a post June 65 200Ci going from the 5 core plugs, fuel pump & colour. Can anyone ID the numbers for me? They are in the photo's but this is what I think they are:
On block below coil "12"
On block below core plugs "06DF 6015B"
As above but closer to front of engine "6M14"
On head "0B23 with an "F" in a circle" at the back
On head above cylinder 4approx "09DE-6090-A" (or maybe that's an R...)
It currently has an "all vacuum dizzy" fitted & the advance (or retard as I understand it's operation) springs are broken. In the pic I removed them.
It has a Holley List 3032-S carb which I believe is a 1909 from the original 144Ci the car would have been fitted with.
Obviously it doesn't run very well with this setup. Been reading a lot about carb & dizzy options on here, what should I be looking to buy as a straight "bolt on" option so I can get it running for now? Preferably I want to stay away from the "loadomatic" all vacuum setup if poss.
Thanks,
Dan
Thanks,
Dan
