If you put anything other than a ford six, You will be Dead to us.Oh good to know. I mean I’m open to other engines, but wanna stay with a 6 cause I don’t want to have to change rear ends and all that, just wanna drive around and cruise lol
Oh I meant if someone has a 250 or whatever that will fit. I just want a good running engine lol I’ve been googling seeing if I can find a long block or something! I ordered that performance book as well.If you put anything other than a ford six, You will be Dead to us.When you get around to tearing the engine down, please let us see if we can find out the cause.
It's a good bit harder to pull both the engine and trans together especially if you doing it by yourself. If you happen to have an Auto Trans then its really easy to just pull out the engine and leave the Trans in the car blocked up plus it will go back together faster again. If you have a Manual Trans then you will find its easier to pull the Trans out first.Well that’s unfortunate. I guess I’ll just see if I can find someone with one to swap it out with for now. Guess I should start unbolting stuff and see how to pull it out. Would pulling trans and engine together be easier or should I just pull the engine? My neighbor said I can borrow his hoist and stand so that’s nice. I just gotta figure out lift points. This sucks man really disappointing
I got an auto, it’s got a trans leak I haven’t started chasing down yet cause of well…other problems lol. But that’s probably what I’ll do and that’s what I did when I did my 350 swap in my el Camino in high school! LolIt's a good bit harder to pull both the engine and trans together especially if you doing it by yourself. If you happen to have an Auto Trans then its really easy to just pull out the engine and leave the Trans in the car blocked up plus it will go back together faster again. If you have a Manual Trans then you will find its easier to pull the Trans out first.
There’s a guy here with a 250 in a running car, he’s gonna let me know when he pulls it for his swap. I did some research on it, luckily my hood is a replacement so it has a indention so if someone wanted to cut it for a cowl or whatever so I think I have some extra clearance. I saw someone said to use maverick mounts and either elongate the holes or drill new holes in frame to mount, which will allow the motor to sit lower. What does suck is I would need V8 bellhousing, torque converter, starter, and while the headers are interchangeable, where the start will be will probably be a problem. Also I’ll have to run electric fan as the length with the harmonic balancer becomes a problem. So yeah it comes with it’s own issues. I had reached out to a guy that had two 200cis for sale on here or VMF I can’t remember and after sending me the info and me telling him I was interested he disappeared haha so my search continues!The 250 six would be a great swap into your car if you could find a good one and they will fit into the 1967 to 1973 Cars with ease if you find the right front motor mounts or are good at fabricating some new parts, modding what you have or if you have a friend that is good at it.
Maybe I should put a want to buy post for parts? Like crank and such? I really wish someone knowledgeable on these were close to me to show me how to do everything I’d pay for their time. I called a local guy and all he told me was “it will cost thousands to rebuild it” and I wrote him off lol. I mean if the cost isn’t to bad I wouldn’t mind upgrading it for durability and maybe some more power etc. but I don’t wanna get too expensive, I’m already on a budget but I’ll figure out how to make it happen.Yes for sure it will be a "Hand Grenade" and it's likely to destroy a good 1967 duel bolt pattern 200 block core. X3 you really don't have much of a chance for success putting in a new bearing set on that damaged #1 crankshaft rod throw. Once you check and measure one of the other good crankshaft rod throws your going to see what your up against on how much clearance you have. Bearings come in Standard, .010, .020, 030, and maybe .040 oversize, if you cant get the rod bearing clearance on #1 in the range of .0008 to .0035 of clearance with the crankshaft journal and rod big end cleaned up it will just hammer itself apart again in short order. Its really not that much more work to put in a fresh crankshaft along with the bearings and another good Rod in the #1 cylinder or a resized one. Some of our site members may have some good used parts too. Best of luck on your 200 six.
I put a WTB ad on VMF, ima do one here as well.Yes for sure it will be a "Hand Grenade" and it's likely to destroy a good 1967 duel bolt pattern 200 block core. X3 you really don't have much of a chance for success putting in a new bearing set on that damaged #1 crankshaft rod throw. Once you check and measure one of the other good crankshaft rod throws your going to see what your up against on how much clearance you have. Bearings come in Standard, .010, .020, 030, and maybe .040 oversize, if you cant get the rod bearing clearance on #1 in the range of .0008 to .0035 of clearance with the crankshaft journal and rod big end cleaned up it will just hammer itself apart again in short order. Its really not that much more work to put in a fresh crankshaft along with the bearings and another good Rod in the #1 cylinder or a resized one. Some of our site members may have some good used parts too. Best of luck on your 200 six.
So if you were in my predicament, what would you change going into it that wouldn’t be a big cost while it’s apart? I like the idea of a different cam, give it a good idle, maybe use a 2V instead of 1V. But I don’t think that’s too crazy.Sure you could put a free add in the wanted section of the this Forum for any parts your looking for, here is the link. https://fordsix.com/forums/wanted.85/
And for a budget stock rebuild master kit with very good quality parts for this price level, here's the link (there are others to depending on your goal for your car. https://www.northernautoparts.com/part/ek-ek0374#options
And here is a Crankshaft Kit. https://www.northernautoparts.com/part/ck-25026
They would likely give you a credit back on the extra Main and Rod Bearings to or other parts you would not want for your rebuild.
Then all you would need to do is locate a locale machine shop to do all the Block Prep, Boring, Rebuild the Rods, and probably also a fresh valve job. After that we should be able to help you with the assembly its not very hard to do on these small sixes'. Best of luck
