Eric Rose
My new motor is running hot. For those of you who don't already know, here are the specs:
200 bored 40 over
9:1 compression
264/274 cam (cam timing is straight up and was degree'd)
Carter YF (running a little rich, need to tinker with it some more)
Duraspark II (8 degrees initial)
160 or 180 thermostat (I forget which)
3 core brass radiator
no fan shroud
'62 four blade fan
aluminum water pump
I run 87 octane, the temperature is around 85
Does anyone know where I can get a fan shroud for the 6 cyl Falcon radiator? Would one from an early V8 Mustang work?
I am also figuring that I will run cooler with a 190 degree thermostat because it will allow the water in the radiator to stay in longer. The cooler thermostat seems like it just opens up and stays open. I have also heard it helps to drill a small hole in the thermostat to let air bubbles escape so if I end up changing the thermostat I will probably do that.
I also got an electric fan today I'm going to try. I am thinking of making brackets to mount it on instead of using the zipties that come with the kit. It can aparrently be configured as a pusher or a puller fan. I am thinking of installing it on the grille side of the core support and setting it up to push air through to the engine side. I am worried that this might block the radiator from the cool air moving in through the grille, however.
Any help, advice, or suggestions would be great.
200 bored 40 over
9:1 compression
no fan shroud
'62 four blade fan
aluminum water pump
