Eric Rose
Is it advanced or retarded timing that will make it run cooler?
I finally got a chance to do a highway run and it got really hot... up to 235 once I started cruising at 60 mph, even with the electric fan.
So I took the fan off, and moved the heater hoses over away from the exhaust. It will run between 190 and 210 at a 55mph cruise now. If I get any deeper into the throttle than that it really starts to climb.
I flushed the coolant again and it was muddy looking again. Must not have enough rust inhibitor. A lot of crud came out of the heater core. I added some prestone "mixes with all other types" antifreeze and some plain tap water because I'm short on $$ right now. The heater hoses look really dirty on the inside (didn't get to them when I replaced the motor). So I will probably flush it again and replace the heater hoses.
I also have the 5 bladed fan from a '78 Fairmont I am thinking of trying.
Does anyone know what I can do for a fan shroud? Will one for a V8 Falcon or Mustang work? Because V8 '65 Mustang fan shrouds are cheap and plentiful. 6cyl Falcon shrouds... not so much
