ive just found a new starter for the XR ,It was running the old lucas m40 of the 200 non cross flow .The new one is a high torque starter with 1.4kw
and the planetary gear set up .If your falcon starter suffers from heat
this unit is smaller overall than the stock unit and should bolt up to almost all of the falcon non cross and crossflow range .These are made in aussie
by ASHDOWNS under the number 0140119. The old bosch type that was standard equipment on alot falcons was only 1.1kw .
hope this can help someone out there.
cheers dave
cheers dave
