stu in wichita
My new radiator is leaking after only a couple thousand miles. It's a crummy Chinese part, as so many are these days. The local radiator shop said most of the imports use a solder with a different lead/tin ratio and it just isn't as strong. He didn't try to sell me a new one but said the rest of the radiator was pretty well-made. He's going to re-solder the tanks and necks and it would be fine.
While I have everything out, I'm tempted to put a new water pump on my '64 170. All indications are that it is the original pump. There is no perceptible play in the bearing and it doesn't leak. I put a stethoscope on the housing, and it runs smooth with no weird noises.
My question is, should I install a new one while it's easily accessible? Or should I take my chances on the one that might be almost 50 years old? I've heard opinions both directions. The new one would likely be a cheap import, which might not last long (kinda like my radiator). How about remanufactured pumps? I think they get all new parts, except for the housing. Because of the A/C coil and my front roll pan, it's a pain to remove the radiator, so I'd like to not be doing this again soon.
What do you guys think? I'd really like to hear from someone who puts some serious miles on their car. My Ranchero will be a regular driver - I've logged 2000 miles since late May, and I'm still sorting things out. Thanks.
-Stu
-Stu
