OK, I think I've finally figured out the timing issues, now I want to dial her in a bit more. Now, the quesitons:
- in what order should things be done: timing, mixture, idle speed
- using a vac gauge on the carb to set mixture...which vac port do I use? I'm supposed to back the mixture screw out until I hit my highest vac point right? Leave it there?
- I've got a Holley 2300 500CFm carb on my OZ2502V head. What kind of jetting should I be looking at using? I have no idea what jets are in it now (stock)...do you?
