All Small Six Offy
mluck
I’ve been running a offy 31bbl for a while now..found a edelbrock F361 I’m going to replace the offy with..I’m cleaning and polishing the Edelbrock..question is should I sand and polished the opening where the carbs sit on..right now there ruff.
Hi, the gasket surface must be perfectly clean and flat. Any roughness inside the bore can be cleaned up. Good luck
