Stang67 Well-known member Jun 11, 2010 #1 How do I stop the oild leak from under my dui dizzy I have the rubber seal under there and its still leaking
M mach1 mark Well-known member Jun 11, 2010 #2 I think Mike has a gasket< I don't know if those came in yet? I made my own, It stopped the leak.
Gene Fiore Famous Member Jun 11, 2010 #4 Sometimes the hold down bracket just doesn't clamp down tight enough. Make sure it is super tight when you tighten the bolt. That fixed my leak.
Stang67 Well-known member Jun 11, 2010 #5 I already got the gasket but its still leaking and the clamp is on tight.
