Ok, thanks for everyone's help on the oil seal/timing chain issue. I finally got my timing chain and gears from Oz today, and now I'm going to attempt to put the whole thing back together.
For those who weren't in on this, I have an Oz 250 engine that had a really sloppy timing chain in it.
In any case, I have a timing cover seal from a U.S. 200 engine, and I'm not 100% sure how to install it. Part of my problem is that I swear the old seal I picked out of there came forward further than this seal does. I'm not too worried about that, unless someone thinks otherwise. Here's a picutre:
Am I right by thinking the spring o-ring (whatever it is) goes toward the rear of the timing cover, and I just push it in place? What's confusing me are the Pro Lock II and that smaller metal ring that they put in there. Also, will the fact that the o-ring doesn't come through the smaller opening, as did the old one, cause a problem?
If someone can help me with some instructions on how to install this thing, I'd really appreciate it.
Thanks, in advance.
Makoto
Thanks, in advance.
Makoto
