Well, I think I've made up my mind to add a turbo. Now, the questions...
I've read MUCH of what is here and I don't remember anyone posting a "best fit" turbo selection. I've read about TBirds, GN's, even Toyotas stuff, but I'm no engineer here fellas. I want a clear cut answer (or at least a very firm suggestion) as to which turbo I should look for (based on mounting and performance matching to my buildup).
To me, my biggest obstacle seems to be the plumbing of the exhaust. I'm running dual out Pacemakers. Can I tie the turbo in at any point or does it need to be at a certain distance from the motor? Can I just cut a T into one pipe AFTER the header collector and duct it back up to the turbo? Anyone tie a turbo to these headers before?
Where does the wastegate go? Plumbed back to the exhaust system somewhere?
What kind of aircleaner/filter would I use in front of the turbo (that's where it goes, right?)
Once it's mounted and the exhaust is plumbed, the rest seems pretty straight forward (oil line if needed, plumbing to the carb, etc). What am I missing?
Anyone have leads on the parts I need?
PS: just to add, I'm willing to sacrifice SOME performance for ease of install and fit. If that means a smaller turbo unit and a little less boost, then so be it.
