So, finally got Susie down to Tampa with me. Prepping her to get her running again, I'm reminded how much I hate electrical issues.
12.75V at the battery, counter-monkey at AutoZoo tested the battery at 670CCA today (rated at 700CCA, two days ago I had it checked at 521CCA, trickle charged it for the past two days to bring it up).
12.75V at the battery, at the solenoid, at the starter.
Try to check the resistance between negative terminal of the battery and the body of the starter, get an out of limits reading. I'm thinking I need to take the starter off and clean everything (aluminum oxide over everything), and possibly clean the plate between the transmission and the flywheel (it's painted)
